GregValiant 1,351
Above the settings area is the Settings Search box. Just to the right of that is a dropdown list for setting visibility. Set it to "All"
Back in the settings go to the Speed section and find "Z-Hop Speed" and set it to 1.5. The backcolor of the textbox should change from red to white and you should be good to go.
Twinjoe 0
I have a Monoprice 33820 printer. It does not appear that this printer is supported on the dropdown menu?
When I try to slice it says the Z hop speed is incorrect.
Can you help a novice?
Thank you
