Need Help with a Monoprice 33820 Printer
Posted · Need Help with a Monoprice 33820 Printer
I have a monoprice printer and it reads *.g and *.gx files.  Cura writes a *.gcode file.  Can Cura write a compatable file format or do I need to use other slice software ?
Help please !
    • 2 years later...
    I have a Monoprice 33820 printer. It does not appear that this printer is supported on the dropdown menu?
    When I try to slice it says the Z hop speed is incorrect.
    Can you help a novice?
    Thank you
    Above the settings area is the Settings Search box.  Just to the right of that is a dropdown list for setting visibility.  Set it to "All"
    Back in the settings go to the Speed section and find "Z-Hop Speed" and set it to 1.5.  The backcolor of the textbox should change from red to white and you should be good to go.
