Posted · Nozzle clearing
When Cura prints a prime blob or performs a nozzle wipe, it always seems to do it *immediately* before moving the print head towards the model. Wouldn't it make more sense to move it away? I've found that things that need the prime tend not to adhere so well, and the printhead routinely drags the prime blob if not into the part, somewhere that it's going to wind up interfering with the part.
The same thing with skirt: I've watched it lay down a beautiful line of skirt that adheres perfectly, but then it travels straight to or across the part footprint with a tiny little dangle of ooze that falls off in the least convenient part of the adhesion layer, or it turns out to be the one place in the print that it's going to string.
Lastly: is it possible to move the print head outside the bed? I just wonder how many prints would go better if the the head couldn't traverse one of the corners of the bed, with and then lower to { first-layer z - first-layer-width/3 } at the very edge of the bed moving - slowly - to first-layer z as it crosses up to the bed... If anything is hanging off the head, this should knock it off, and the trip along the side and round the corner should help to drag any ooze or string off the plate? (Yeah, it sounds too easy, so I suspect it's not or you'd have done it 🙂
          • Heart
        • 4 replies
