Ron
RonBreukers
SOFTWARE BUGS IN 5.2.8???
I own an Ultimaker3 and was very happy with it until I did the day before yesterday the software update to version 5.2.8 Since then, the measured temperature of the build plate jumps at once to 60 degrees and (of course) the build plate does not heat up anymore.
I tried a factory reset, and the only effect was that now I cannot get the WIFI to connect and no improvement to the build plate. The only thing was that immediately after the reset I set the temperature of the build plate manually, and that worked. Once I tried to print someting the same happened as before and the indicated build plate temperature jumped from 32 degrees to 60 degrees.
PLEASE is there a way to get back to a previous version of the software. Remember - no WIFI, and if I interpreted the data correctly - also no update with the USB.
Ron Breukers
