Cura Misses out section of Print
Posted (edited) · Cura Misses out section of Print
I have a super weird problem and I'm not sure whats going on. When in Cura the 3d model looks absolutely fine, as you can see with the inside part being on a slope.
But when I process the gcode, that part is completely missing and the inside is flat?
anyone have any idea whats going on here? I can supply you with the .stl if you want to have a mess around
Edited by dannywrayuk
