Optimizing this print
kfsone
Posted · Optimizing this print
UM3 bed got out of level and I wound up making settings tweaks that didn't help, and now I'm trying to back them out, but as I scrutinize how the build gets printed, some of it is counter to my *novice* intuition.
If you watch the first layer, it starts laying down the wall around the "window" panels and the speeds are kinda weird:
then it makes an odd choice about where to start the next panel, resulting in a bunch of extra travel that could have been eliminated if it started at a different point:
the order in which it does these next pieces is a bit puzzling too - in that it works left, bottom middle, right, center, top right, left, for all of which it only does half the lines. Then it does the outer perimeter in full before going back and finishing the window-walls; then it fills the rest of the face:
and even then, it goes back around and puts more lines directly around each wall.
The other issue I'm having is that there are weird patterns on the bottom surface because of the way it tries to fill the base resulting in a surface that (in a kind of cool way) has a panelized look, like an 80s starship surface heh.
And whether I use lines or zigzags, the way in which seams form between the contiguously printed panels and resulting travel significantly affects the smoothness and rigidness of the bottom surface: the marked lines show up as clear seams/distinctive "panels" on the bottom surface:
Is this where perhaps I should be using concentric? I gave that a shot and it had the same outlining wastage and then it did this:
It seems a lot like Cura could have made things easier on itself if it had realized that it's dealing with a round/symmetric design? The resulting seams are actually kinda neat:
But they still somewhat marr the finished surface which - went it adheres properly - is a beautifully flat, smooth surface.
I've attached the print and the settings I'm using, I'd love any input on what I'm doing wrong and how I can produce a better print?
-Oliver
Insert image from URL
spool.3mf spool.curaprofile
