Cura from source, python virtualenv
FPS_Budd_Dwyer
Posted · Cura from source, python virtualenv
Abstract
Since the current e-build of Cura for my distro has issues I decided to just get the source from git up and running. Additionally, I wanted this in a virtual python environment so I didn't have to worry about conflicts with my system or python upgrades. (amd64 gentoo 4.19.44)
Resources
Please read the following two articles. They are brief and very well done. However neither of these worked for me exactly as written so I wanted to submit my log here in hopes that it may help others.
  1. https://github.com/Ultimaker/Cura/wiki/Running-Cura-from-Source-on-Ubuntu
  2. https://github.com/Ultimaker/Cura/wiki/Running-Cura-from-Source-on-openSUSE
Create the Python virtual environment, activate it, and install the dependencies
cd ~/virtualenvs
virtualenv -p /usr/bin/python3.5 Cura
source ./Cura/bin/activate
pip3 install pyserial PyQt5==5.10 requests scipy numpy shapely zeroconf
Build dependencies under /usr/local/src :
note: use an appropriate distro location, on my system that is /usr/local/src
Create a CuraEnv folder to hold everything.
cd /usr/local/src/
mkdir CuraEnv
cd CuraEnv
note: Always return to this folder before installing the next sub package
libCharon
git clone https://github.com/Ultimaker/libCharon
cd libCharon
python3 setup.py build
python3 setup.py install
note: install will build and install but I like to go slow and read outputs
note: sudo is not needed for install due to the virtualenv
sip
wget https://sourceforge.net/projects/pyqt/files/sip/sip-4.19.13/sip-4.19.13.tar.gz
tar xzvf sip-4.19.13.tar.gz
cd sip-4.19.13
python3 configure.py
make -jn -ln
sudo make install
 note: With regards to make -j and -l are completely optional, they are arguments for number of threads and load respectively.
 note: sudo is needed here because ~/virtual/Cura/include is a symbolic to /usr/include which needs elevated permissions for write
protobuf
git clone https://github.com/google/protobuf.git
cd protobuf
git checkout 3.5.1.1
mkdir build-dir
cd build-dir
cmake ../cmake -Dprotobuf_BUILD_TESTS=OFF
Be sure to add the -fPIC flag to CMAKE_CXX_FLAGS to the CMackeCache file as noted in the Ubuntu guide.
Quote
In the newly created CMakeCache.txt file, change the CMAKE_CXX_FLAGS:FLAGS property to -fPIC
Build and install
make -jn -ln
sudo make install
libArcus
git clone https://github.com/Ultimaker/libArcus.git
cd libArcus
mkdir build && cd build
cmake -DCMAKE_INSTALL_PREFIX=/usr ..
make -jn -ln
sudo make install
CuraEngine
git clone https://github.com/Ultimaker/CuraEngine.git
cd CuraEngine
mkdir build
cd build
cmake ..
make -jn -ln
sudo make install
libSavitar
git clone https://github.com/Ultimaker/libSavitar.git
cd libSavitar
cmake ..
make -jn -ln
sudo make install
Uranium
git clone https://github.com/Ultimaker/Uranium.git
fdm_materials
git clone https://github.com/Ultimaker/fdm_materials.git
Cura
cd Cura
mkdir resources/materials
ln -s /usr/local/bin/CuraEngine .
ln -s /usr/local/src/fdm_materials resources/materials/fdm_materials
Set PYTHONPATH start and test
PYTHONPATH=$PWD/../Uranium:$PYTHONPATH python3 cura_app.py
Extra Credit
Hopefully all went well and you are probably sick of a terminal by now.
Let's add a quick launcher script so you can have easy access via your window manager.
cd /usr/local/bin
sudo nano vim /usr/local/bin/cura
paste this block, save and close
#!/bin/bash
#Start up the virtual python env
source ~/virtualenvs/Cura/bin/activate
#Change Directory
cd /usr/local/src/CuraEnv/Cura
#Set env and start...
#send stderr to log and dump stdout
PYTHONPATH=$PWD/../Uranium:$PYTHONPATH python3 cura_app.py 2>/var/log/cura.log >/dev/null &
make it executable
sudo chmod +x /usr/local/bin/cura
Add /usr/local/bin/cura to your launcher of choice and use the icon from the cura/icons folder to make it pretty.
Happy printing.
  • Thanks 1
