Cura ignoring support pattern?
desultroy
Posted · Cura ignoring support pattern?
Hello burtoogle,
Your correct. That is support interface. When I disable Support Interface and Support Roof, I get a support pattern for the complete generated support. I will try again... The default support was near impossible to remove, because it was 8 layers of support interface sandwiched inside the model.
[Turns out the model is not suitable for my newer style anycubic printer. So a reprint with new settings will have to wait until i learn how to modify the model.]
Thank you
