Unexpected pause at layer change
FPS_Budd_Dwyer
Posted (edited) · Unexpected pause at layer change
Just wanted to share in case it helps someone.
Running the current master branch from git and had an odd pause during layer changes.
Long story short:
The profile for my printer (Ender 3) did not have a "Maximum Z Speed" which generated the following G Code
G1 F17987547480000 Z0.3
G Code involving other axis calculated correct speeds.
e.g.
G0 F1500 X112.719 Y99.571 Z1.3
Inserting a value to "Maximum Z Speed" resolved this issue.
Edited by FPS_Budd_Dwyer
