We need to set up in a CURA profile for CR-10 Max, help!
drgearsmith
Posted · We need to set up in a CURA profile for CR-10 Max, help!
Just now, DidierKlein said:
I would most probably choose one of the Cr10S printers and change the printer dimensions... the rest should be pretty similar
Hey thank you for quick reply! Will give it a shot
    Hmm we created a model and tried the CR10S profile and when we loaded the card with the gcode for the model the machine could not see the file. We used the creality software for the same model and it could see the file but not the one made in cura... not sure what to try next
    On 7/21/2019 at 9:07 AM, drgearsmith said:
    Solved: So you cannot use any special characters in the file name! It was that simple
    hello
    your CR10 Max with the profile CR10S in cura always start with autolevel?
    apart of the printer dimensions did you change something else?
    thanks
