I increase the feed rate speed manually but it does not work
Turan
Posted · I increase the feed rate speed manually but it does not work
Hello,
Previously, while I change the feed rate manually, e.g. from 100% to 200% the speed of the feed also increased in 3d printer. However, it is not changed now while I alter it manually. What is the problem? It should work actually.
