Thin Wall Printing: drops next to start/end point
marvin_s
Posted · Thin Wall Printing: drops next to start/end point
Hello,
I'm trying to print my first plane from 3DLabPrint (Messerschmitt Bf 109H) on an Ultimaker S5. I'm using Cura 4.5 for slicing and Ultimaker silver metallic PLA as printing material. Thin wall printing is completely new to me.
Meanwhile, the outer surface of the part looks relatively good but I'm struggling with the inner structures which don't look good at the starting and ending points (see photo attached). They seem to be a little shifted from the actual starting/ending point. Some of them look like little imprints from the nozzle. I've never had that problem before when printing my usual (thick wall) parts.
The current printing profile (attached, too) is the result of a lots of things I tested and read on several webpages.
Do you have any recommendations on what to do? Might it help to vary temperature or retraction settings? At the beginning of my printing tests for that parts, that problem wasn't there. So might it be, that it is some hardware problem with my printer? I attached a picture of the travel ways from Cura, too.
Appreciate your help!
profile.curaprofile
