Creality cp-01
  • 2 months later...
Posted · Creality cp-01
Hello, @scobner and @MIKE88
Did you get anywhere with this? I just got a creality CP-01 and I am having problems printing from Cura V 4.6.1.
Essentially, any model I try to print from Cura only lays down the first layer and then the filament stops extruding, but the print head keeps going through the motions. It even makes a slight high pitched buzzing noise when this seems to happen.
In contrast, I know the printer is working, because I can successfully print the stock models that came with the machine, like tuzi. Even more perplexing is that if I try to open the tuzi gcode in Cura, it says that the file is invalid.
Have either of you encountered this?
Thanks
Kevin
    • 1 year later...
    I have this machine too.
    Some people says that the fan generates interference; so they suggest this configuration in Cura:
    It solved the proble temporary, put now it`s happening again
        • 1 reply
