Experimental Spaghetti infill produces strange preview
StarNamer
Posted (edited) · Experimental Spaghetti infill produces strange preview
Having noticed that CURA 4.5 was available, I read the release notes and was interested to see what effect Spaghetti Infill had. I tried it on an STL file I happened to have (Z rod knob for Ender 3 -  http://www.thingiverse.com/thing:3568572) and got a very strange preview at layer 25:
The profile I was using was the default Low Quality with the following changes:
  Infill Density: 40%
  Print Speed: `130mm/s
  Initial Layer Speed: 40mm/s
  Support Placement: Touching Buildplate (but Generate Support is off)
  Tree Support: On
  Spaghetti Infill: On
There doesn't seem to be anything odd about the GCode and it looks fine when loaded:
Of course, when looking at the infill, it's not clear what would happen as the Cubic infill is missing several layers and would, I expect, become spaghetti! Perhaps that's what's intended?
CE3_Z_Knob_apl - spaghetti error.gcode
Edited by StarNamer
