Initial Line Width of Support ?
chrii
Posted (edited) · Initial Line Width of Support ?
Hello 🙂
I`m printing with a 0.4mm Nozzle on my Orca with DD Extruder.
i``m using 0.2mm layer width for Support line width this way it is still stable enough to support the print but it is much easier to remove.
For sure 0,2mm layer widh does not stick very well to the baselayer of the printer.
Is there any reason why Support is not part of the Initial layer width ?
Would be great if this would also be added to the initial layer.
Kri
Edited by chrii
