Does it bring the ulticontroller if I buy assembled UM1?
dajrota
Posted · Does it bring the ulticontroller if I buy assembled UM1?
The Ultimaker Original Assembled is being shipped with an UltiController and all other upgrades available for the Ultimaker Original.
The Ultimaker Original does require some technical knowledge to operate, which you usually learn when building the Kit.
If you already have experience with Ultimaker there should be no difficulties.
The Ultimaker 2 is easier to operate and is also equipped with a heated bed. It comes pre-build too.
For just €1895 the Ultimaker 2 is also available.
Perhaps something you want to consider.
