Here is the log, backed up the old one and let it create a new one for this instance only to cut down on clutter.
Everything else does detect it on Com 7.
Cura 4.6.1 won't see my Ender 3
Are there any other devices that might be interfering on that COM port? Or is it possible your printer's board has been damaged somehow? Some clues are in your log:
2020-05-04 16:27:46,823 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 500000 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:27:49,247 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to MonitorStage
2020-05-04 16:27:49,255 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/plugins/PrepareStage/PrepareMenu.qml:25: TypeError: Cannot read property of null
2020-05-04 16:27:49,258 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/plugins/PrepareStage/PrepareMenu.qml:26: TypeError: Cannot read property of null
2020-05-04 16:27:49,288 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
2020-05-04 16:27:49,292 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
2020-05-04 16:27:51,328 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 230400 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:27:52,830 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
2020-05-04 16:27:54,096 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [56]: Default machine actions have been added for machine definition [creality_ender3pro], do nothing.
2020-05-04 16:27:54,101 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [179]: Extruder [creality_base_extruder_0 #3] has already been added to this stack [Creality Ender-3 Pro]
2020-05-04 16:27:54,105 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #3] has already been registered on machine [Creality Ender-3 Pro], not doing anything
2020-05-04 16:27:54,115 - INFO - [MainThread] UM.Logger.info [122]: Initializing Active Machine...
2020-05-04 16:27:54,462 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
2020-05-04 16:27:54,467 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
2020-05-04 16:27:55,832 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 57600 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:28:00,336 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 38400 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:28:04,840 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 19200 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:28:09,344 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 9600 works. Retry nr: 0. Wait timeout: 3
2020-05-04 16:28:17,591 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [56]: Default machine actions have been added for machine definition [creality_ender3pro], do nothing.
2020-05-04 16:28:17,594 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [179]: Extruder [creality_base_extruder_0 #3] has already been added to this stack [Creality Ender-3 Pro]
2020-05-04 16:28:17,597 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #3] has already been registered on machine [Creality Ender-3 Pro], not doing anything
2020-05-04 16:28:17,606 - INFO - [MainThread] UM.Logger.info [122]: Initializing Active Machine...
2020-05-04 16:28:18,072 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
2020-05-04 16:28:18,078 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
2020-05-04 16:28:28,848 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 115200 works. Retry nr: 1. Wait timeout: 15
2020-05-04 16:28:32,293 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [56]: Default machine actions have been added for machine definition [creality_ender3pro], do nothing.
2020-05-04 16:28:32,298 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [179]: Extruder [creality_base_extruder_0 #3] has already been added to this stack [Creality Ender-3 Pro]
2020-05-04 16:28:32,303 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #3] has already been registered on machine [Creality Ender-3 Pro], not doing anything
2020-05-04 16:28:32,310 - INFO - [MainThread] UM.Logger.info [122]: Initializing Active Machine...
2020-05-04 16:28:32,854 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
2020-05-04 16:28:32,859 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
2020-05-04 16:28:49,855 - DEBUG - [Thread-3] USBPrinting.AutoDetectBaudJob.run [50]: Checking COM7 if baud rate 250000 works. Retry nr: 1. Wait timeout: 15
I can't think of anything that would be interfering. And as I said, it connects fine to Simplify3D and Pronterface, so I don't think there would be damage since they should all be using the same connection protocols. That is what had me stumped.
maht 89
That's weird. Can you share a log?
https://github.com/Ultimaker/Cura#logging-issues
