Possible improvements in the Factory Reset Option
chelys
Posted · Possible improvements in the Factory Reset Option
Hi, I would like to suggest you an improvement to the Factory Defaults reset option of the UM2.
During an investigation about a failure of my printer and after completing the first installation with success I have reset the printer to the factory defaults.
The problem was that the printer had already the filament loaded. As it was not possible to skip this step during the initial setup, the printer tried to load again the filament with the result of "consuming" the small piece of filament inside the feed motor.
The consequence was that the printer was not more able to feed the extruder.
PS:I have not checked if the problem is still present with the latest firmware upgrade.
