X-axis shift before ironing
zabnat
Posted · X-axis shift before ironing
I have on weird problem. I get a about 4 mm shift on the x axis before the ironing feature. It always happens on just before ironing. My printer is JGAurora A5. I suspect it is printers fault. I think (not sure) it shifted on the first print but not on the second. Just wondering if there is something on the ironing that might cause this? Is there a way to test the generated gcode to see if the problem is there?
