Priming between infill and walls
VMaxx
Posted · Priming between infill and walls
I'm giving a mixing nozzle a try for the first time.
I have it setup with the two extruders the second has HIPS in it for support.  I have it set so that extruder 1 is my regular filament and 2 for support.
It seems to be priming between doing walls and infill unexpectantly.  I found a setting for infill extruder and it was set to "not overriden" so I changed it to match extruder 1, but it  still does a prime after doing the wall and infill wasting filament.  I'm wondering if I'm missing something if anyone has seen this.
TIA!
    Ok its apparently not between infill and walls.  Its doing walls and infill then priming and doing a second pass of wall and infill, then primes to do support.
