Support X/Y Distance
Cuq
Posted · Support X/Y Distance
Hello,
When Y use a Mesh as support , Cura Use the value set in the Profil as Support X/Y distance and not the value define for the element support.  Is there any solution to use the value set on the element ? and keep the global X/Y distance for the other support ?
        • 2 replies
