CR-X settings way off
Posted · CR-X settings way off
Hi there.
Great program, however the machine settings and some code are way off. Jost install the slizer from creality and copy settings over.
Is there a way to swrite to support or anything ?
Fx Printer Head Size options all need to be editit to 0
Heat bed recomended 60 (screws up) however works best at 75 degree
Start code has to be
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21        ;metric values
G90        ;absolute positioning
M82        ;set extruder to absolute mode
M107       ;start with the fan off
G28 X0 Y0  ;move X/Y to min endstops
G28 Z0     ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0                  ;zero the extruded length
G1 F200 E3              ;extrude 3mm of feed stock
G92 E0                  ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
End code
;End GCode
M104 S0                     ;extruder heater off
M140 S0                     ;heated bed heater off (if you have it)
G91                                    ;relative positioning
G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
M84                         ;steppers off
M81
;{profile_string}
Start 2
G21        ;metric values
T0                      ;Switch to the first extruder
G1 F3600 E110           ;extrude 10mm of feed stock
G1 F{travel_speed}      ;extrude 10mm of feed stock
M117 Printing...
End 2
G92 E0
G1 F12000 E-110
M104 T0 S0                     ;extruder heater off
M104 T1 S0                     ;extruder heater off
M84                         ;steppers off
;{profile_string}
        • 28 replies
