Cura Segmentation fault on startup
keith-miller
Posted · Cura Segmentation fault on startup
I'm running this on a Udoo, in preperation for building a 3d printer. Its a arm v7 quad cpu, 12.04 linaro distro. (12.04 ubuntu based)
cura engine compiled and seems to run fine.
load cura.py and I see logo, 30 seconds later, it seg faults.. I can post a log or something if someone tells me where to find it.. I'm still very much a linux noob..
    • 3 months later...
    Hi Keith,
    Did you ever manage to fix this? You're the only other person online I've found that's trying to run Cura on a Udoo.
    For me Cura ran the first time but then through back a segmentation fault every time after.
    I also tried completely removing the Cura installation and starting again but had the same issue which I think points to an opengl issue rather than a problem with Cura (but I could be wrong).
    I'd be interested to see if you've made any progress.
    I too am a noob. :)
