Plugin path on Mac - Cura
Posted · Plugin path on Mac - Cura
Hello ! I'm Damiano and I use Cura in one PowerWasp
I have a problem to find the path where to find the plugin .. I use Mac
I would have a plugin that change the temperature when the layer is short !
Do you recommend anything?
I find Thermostat on web but i can't try it.. If you want i share the code
Thank you !
