support doesn't touch build plate in Cura
SimonQuinn
Posted · support doesn't touch build plate in Cura
I have googled this subject and it doesn't seem anyone had an answer for it.  But when i select support placement "Everywhere", the support structure isn't sliced from the buildplate.  The support starts around Layer 4 or 6 depending on my layer resolution.  is there a setting that i am missing?  When i select "Touching Buildplate" the Support structure starts on the first layer.  i tried to use that setting as guide to try and find out what settings has changed but i cannot find it.
        • 21 replies
