Help requested - slicing issue causes Clog - iron like behaviour top/bottom layers that could be walls
So it seems to be related to the number of top surface skin layers- -if I set 0 then the issue goes away. If I set 1,2,3 etc then the issue comes back. I had been using top surface layers to get better finish to the print - some help in what I can adjust would be welcome.
Edited by geekyhawkes update
geekyhawkes 0
Alternate video URL
Edited by geekyhawkesupdate
