printer is retracting a lot
bteddy
Posted · printer is retracting a lot
Hello,
I am using:
Anycubic I3 Mega
Cura 15.05.6
PLA
My printer has started retracting a lot. I went into Cure / Info/Filament to run just the extruder and it does the same thing.
It will run forward a little but not extrude anything /or very little then retract.
I have:
* unplugged the unit.
* reset the unit.
* switched to different stl files
* changed settings up and down in Cura
Any ideas???
My Settings are
[BASIC]
Layer height:0.15mm
Shell Thickness: 2mm
Enable retraction" ckecked
Bott/Top thickness: 2mm
Fill Density: 75%
Print speed: 40
Print Temp: 215
Bed Temp: 60
Support type: None
Platform adhesion type: None
Diameter: 1.75mm
Flow: 100%
Nozzle size: 0.4mm
[Advanced]
Retraction speed: 40
Retraction Distance: 1.5mm
Initial layer thickness: 0.3mm
Initial layer line width: 140%
Cut off object:0.0
Dual extrusion overlap: 0.15mm
Travel speed:60
Bottom layer speed: 40
infill speed: 60
Top/Bottom speed:40
Outer shell speed:40
Inner shell speed:60
Minimal layer time: 1.5 sec.
Enable cooling fan: checked
[Expert config]
Retraction minimum travel: 3mm
Enable combing: No skin
Minimal extrusion before retracting:0.4
Z hop:0.0
Thank You
