Label (or image) for front print bed?
mzagrabe
Posted · Label (or image) for front print bed?
Hello,
I am running Cura 4.5 and have searched the internet and forums, but have not found an answer to my question.
Is it possible to label (or insert an image) for the front of the bed in Cura's 3D view of the print and bed surface?
I know I can look to see where the X axis is and then make sure I look at the printer when applying my adhesive, but it would be neat if Cura had the option to label which edge of the bed square is the "front" of the printer.
Thanks for any help!
-m
