Clean the system fans of the Ultimaker S5
David299792
Posted · Clean the system fans of the Ultimaker S5
I inteded to clean the system fans of an Ultimaker S5 as the manual instructs.
Is one really supposed to blow compressed air into the printer in order to remove particles?
As far as I can assess, they would remain inside if not blown even further inside.
Furthermore, which pressure is applicable?
Thanks in advance!
