Crashing during install / setup
dlpinokc
Posted · Crashing during install / setup
hi, im on windows 10, 8gb memory...can run and use cura 4.6 no problems...i try to install cura 4.7 and it exits, no messages during the setup/run of the program.. here is my log file
thank you in advance!
2020-09-03 19:54:47,920 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
2020-09-03 19:54:47,950 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
2020-09-03 19:54:47,970 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
2020-09-03 19:54:47,990 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
2020-09-03 19:54:48,008 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
2020-09-03 19:54:48,016 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-09-03 19:54:48,016 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
2020-09-03 19:54:48,026 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.7.0
2020-09-03 19:54:48,035 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
2020-09-03 19:54:48,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2020 Ultimaker
2020-09-03 19:54:48,045 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-09-03 19:54:48,055 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
2020-09-03 19:54:48,060 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
2020-09-03 19:54:48,065 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
2020-09-03 19:54:48,065 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
2020-09-03 19:54:48,080 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2020-09-03 19:54:48,085 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
2020-09-03 19:54:48,085 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2020-09-03 19:54:48,095 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
2020-09-03 19:54:48,105 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
2020-09-03 19:54:48,115 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
2020-09-03 19:54:48,115 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
2020-09-03 19:54:48,126 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
2020-09-03 19:54:48,160 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
2020-09-03 19:54:48,180 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
2020-09-03 19:54:48,200 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
2020-09-03 19:54:48,235 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
2020-09-03 19:54:48,251 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
2020-09-03 19:54:48,275 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
2020-09-03 19:54:48,290 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
2020-09-03 19:54:48,305 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
2020-09-03 19:54:48,327 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
2020-09-03 19:54:48,351 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
2020-09-03 19:54:48,370 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
2020-09-03 19:54:48,385 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
2020-09-03 19:54:48,400 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
2020-09-03 19:54:48,425 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
2020-09-03 19:54:48,440 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
2020-09-03 19:54:48,465 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
2020-09-03 19:54:48,490 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
2020-09-03 19:54:48,510 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
2020-09-03 19:54:48,527 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
2020-09-03 19:54:48,570 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-09-03 19:54:48,575 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-09-03 19:54:48,580 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-09-03 19:54:48,590 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-09-03 19:54:48,595 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-09-03 19:54:48,600 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-09-03 19:54:48,605 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
2020-09-03 19:54:48,610 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
2020-09-03 19:54:48,627 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
2020-09-03 19:54:48,645 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
2020-09-03 19:54:48,665 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
2020-09-03 19:54:48,695 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
2020-09-03 19:54:48,715 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
2020-09-03 19:54:48,735 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
2020-09-03 19:54:48,755 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
2020-09-03 19:54:48,775 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
2020-09-03 19:54:48,805 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
2020-09-03 19:54:48,827 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
2020-09-03 19:54:48,850 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
2020-09-03 19:54:49,055 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
2020-09-03 19:54:49,075 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
2020-09-03 19:54:49,085 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
2020-09-03 19:54:49,545 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
2020-09-03 19:54:49,800 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
2020-09-03 19:54:49,970 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
2020-09-03 19:54:50,095 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
2020-09-03 19:54:50,120 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
2020-09-03 19:54:50,140 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
2020-09-03 19:54:50,160 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
2020-09-03 19:54:50,175 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
2020-09-03 19:54:50,200 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
2020-09-03 19:54:50,220 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
2020-09-03 19:54:50,235 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
2020-09-03 19:54:50,255 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
2020-09-03 19:54:50,275 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
2020-09-03 19:54:50,291 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
2020-09-03 19:54:50,311 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
2020-09-03 19:54:50,329 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
2020-09-03 19:54:50,345 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
2020-09-03 19:54:50,360 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
2020-09-03 19:54:50,380 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade462to47
2020-09-03 19:54:50,400 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
2020-09-03 19:54:50,420 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
2020-09-03 19:54:50,435 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
2020-09-03 19:54:50,460 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
2020-09-03 19:54:50,465 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [373]: Loading all plugins took 3.7747435569763184 seconds
2020-09-03 19:54:50,500 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
2020-09-03 19:54:50,545 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [175]: Checking and performing updates took 0.045194149017333984
2020-09-03 19:54:50,555 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [226]: The preferences file cannot be found or it is corrupted, so we will use default values
2020-09-03 19:54:50,565 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [235]: The preferences file 'None' cannot be found, will use default values
2020-09-03 19:54:56,810 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [361]: Loading metadata into container registry took 5.865018129348755 seconds
2020-09-03 19:54:56,840 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
2020-09-03 19:54:56,850 - INFO - [MainThread] cura.CuraApplication.run [781]: Initializing machine error checker
2020-09-03 19:54:56,855 - INFO - [MainThread] cura.CuraApplication.run [786]: Initializing machine manager
2020-09-03 19:54:56,865 - INFO - [MainThread] cura.CuraApplication.run [791]: Initializing container manager
2020-09-03 19:54:57,140 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
2020-09-03 19:54:57,225 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Ultimaker_Cura_4_7\resources\themes\cura-light\theme.json
2020-09-03 19:54:58,295 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [246]: Loaded theme C:\Ultimaker_Cura_4_7\resources\themes\cura-light
2020-09-03 19:55:05,065 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [336]: Creating post processing plugin view.
2020-09-03 19:55:05,070 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ChangeAtZ
2020-09-03 19:55:05,075 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: ColorMix
2020-09-03 19:55:05,080 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayFilenameAndLayerOnLCD
2020-09-03 19:55:05,080 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: DisplayProgressOnLCD
2020-09-03 19:55:05,080 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: FilamentChange
2020-09-03 19:55:05,085 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: InsertAtLayerChange
2020-09-03 19:55:05,085 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: PauseAtHeight
2020-09-03 19:55:05,090 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: RetractContinue
2020-09-03 19:55:05,090 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: SearchAndReplace
2020-09-03 19:55:05,095 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: Stretch
2020-09-03 19:55:05,095 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: TimeLapse
2020-09-03 19:55:05,095 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [202]: Begin loading of script: UsePreviousProbeMeasurements
2020-09-03 19:55:06,235 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [346]: Post processing view created.
2020-09-03 19:55:06,971 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-09-03 19:55:06,985 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-09-03 19:55:07,005 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2020-09-03 19:55:09,025 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
2020-09-03 19:55:10,340 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2020-09-03 19:55:10,350 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Ultimaker_Cura_4_7/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
2020-09-03 19:55:11,355 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
2020-09-03 19:55:11,555 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [117]: Creating model checker view.
2020-09-03 19:55:11,645 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [126]: Model checker view created.
2020-09-03 19:55:11,665 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
2020-09-03 19:55:12,035 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [544]: Requesting [updates] metadata from server.
2020-09-03 19:55:12,050 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [124]: No auth data to retrieve the access_token from
2020-09-03 19:55:12,055 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
2020-09-03 19:55:12,080 - DEBUG - [MainThread] cura.CuraApplication.run [830]: Booting Cura took 26.03018593788147 seconds
2020-09-03 19:55:12,080 - DEBUG - [Thread-1] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
2020-09-03 19:55:12,085 - DEBUG - [Thread-1] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
2020-09-03 19:55:13,675 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
2020-09-03 19:55:13,700 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [38]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
2020-09-03 19:55:13,715 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [62]: Updating QualityProfilesDropDownMenuModel.
2020-09-03 19:55:13,725 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [74]: No active GlobalStack, set quality profile model as empty.
2020-09-03 19:55:14,265 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
2020-09-03 19:55:14,288 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
2020-09-03 19:55:14,297 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  2.1.0 - Build 8.15.10.2900
2020-09-03 19:55:14,305 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
2020-09-03 19:55:14,313 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics
2020-09-03 19:55:14,319 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    1.20.0
2020-09-03 19:55:14,326 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\default.shader]...
2020-09-03 19:55:14,713 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\selection.shader]...
2020-09-03 19:55:15,084 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\select_face.shader]...
2020-09-03 19:55:15,453 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\default.shader]...
2020-09-03 19:55:15,820 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\composite.shader]...
2020-09-03 19:55:15,844 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\overhang.shader]...
2020-09-03 19:55:15,963 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\striped.shader]...
2020-09-03 19:55:16,068 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\transparent_object.shader]...
2020-09-03 19:55:16,186 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\striped.shader]...
2020-09-03 19:55:16,289 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\xray.shader]...
2020-09-03 19:55:16,757 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\xray_composite.shader]...
2020-09-03 19:55:16,789 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\platform.shader]...
2020-09-03 19:55:16,917 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Ultimaker_Cura_4_7\resources\shaders\xray.shader]...
2020-09-03 19:55:22,630 - INFO - [MainThread] cura.CuraApplication.writeToLog [595]: User accepted the User-Agreement.
cura.log
    finally got it to start..i used the CuraEngine.exe from 4.6 and put it in the 4.7 folder and renamed the 4.7 CuraEngine to CuraEngine47.exe...and it started.... hope this helps someone until they can find out whats going on
    well, i cant slice...everything loads fine, i see the new features, but when i try to slice, im guessing its using the old engine and that causes the slice to hang... so the CuraEngine is the problem... 4.6 lets me load and 4.7 doesnt...anyone?
