I should note: speeds stay consistent between the two slicing programs for the base of the retraction test object, it's only for the thinner circular uprights that Cura cuts the "extrude speed" by 3/4ish. Just can't find the setting causing that. Also pretty annoyed that manually setting print speed of inner and outer walls doesn't have the corresponding effect, it still reduces speed regardless.
Nevermind, solved this myself, feel free to delete this thread.
Turns out the cooling fan setting of minimum layer time was slowing the extruder and causing my stringing. Cut the default 10s down to 2 and problem was solved.
endobengo 0
Edited by endobengoLink to post
