Best material to use
Roshdieh
Posted · Best material to use
I want to print some bushes shape cylinders (35mm width an 20mm height) to be used as a bushes for a spigot connection pivot point. They will bear 40 kg vertical compression dead load.  Which type of filament is the best for this situation to be printed with?
