I realize that it’s been a while since you posted but I’ve also had a similar problem. I had a print that was 2hrs away from finishing a 3.5 day print and the support print head became non-repairably blocked. The only available option was to swap the print nozzle or to remove the original print nozzle for cleaning. Swapping the print nozzle gave me an over temp error which is impossible to clear without restarting the machine (why?). After restart there is no way to recover the print.
I was hoping to edit the code to restart at the most recent layer but I can’t seem to start the print without the auto-levelling or nozzle height test. I’m also not able to ssh in to the machine after the most recent update so I’m not sure if there’s some way I could start it from there?
I haven’t moved the build plate in the hopes that someone here may be able to provide some advice?
help? :P
jcrscott 0
help? :P
