HOMERS Odysseus / TEVO® Tarantula RS
erikprosa
Posted (edited) · HOMERS Odysseus / TEVO® Tarantula RS
Dear friends.
I purchased a HOMERS Odysseus as my first printer. However, there is no Cura profile for this printer.
I am using the Tevo Tarantula Pro Profile. The principle is working. However, the G-Code generates an M105 in which the printer is paralyzed. I am removing it manually in a text editor.
Does anyone make the HOMERS Odysseus / TEVO® Tarantula RS profile available?
Grateful for the attention.
Caros.
Adquiri uma HOMERS Odysseus como minha primeira impressora. Porem não tem perfil no Cura para esta impressora.
Estou utilizando o Perfil da Tevo Tarantula Pro. A principio está funcionando. Porem, o G-Code gera um M105 no qual a impressora fica paralisada. Estou removendo manualmente em um editor de texto.
Alguém disponibiliza o perfil da HOMERS Odysseus / TEVO® Tarantula RS?
Grato pela atenção.
Edited by Smithy
Put the English version on top
    • 1 month later...
    • 1 month later...
    HI
    The same problem  have a homer tarantula rs an looking to update profile to cura last version.
    i have put the tarantula pro and change de bed dimension 250x250x260 to 235x235x240
      and add to change Z Hop Speed to 5 beacause it came 10. but some prints are not ok
    Edited by netcaboman
