Ultimaker 2 Extended + build plate stops heating after initial layer
gilee
Posted · Ultimaker 2 Extended + build plate stops heating after initial layer
Hello. My 3D printer won't heat up or sometime it will heat up and stop after the first few layers is printed. What should I check for to fix the problem? Thanks!
Henry
