Please Relocate Home Buttons on Monitor Screen
dazus
Posted · Please Relocate Home Buttons on Monitor Screen
I've found that the position of the home buttons in the monitor screen are in a dangerous place the hard way. All the jog position buttons are small and located very close together, which makes it very easy to accidentally press the wrong one. If you are changing colors in the middle of the print, having the Z home button between the up and down arrows is very dangerous. Twice now, despite being very careful, I have accidentally pressed the home button and tried to drive the print head through my print. I'm very lucky I did not damage my printer in the process. I've also found that, once I do this, there's no way to countermand the order. All I can do is DIVE for the printer's power switch.
I would recommend making all the jog buttons larger, placing more space between them (half the width of a button preferably) and PLEASE move the home buttons so they are far from the other jog buttons.
