Tool change gcode and start gcode
jacobdobbratz
Posted · Tool change gcode and start gcode
Hey Jacob,
I have the same issue but the code doesn't appear when I click into the box?
On a side note, when I look at my start/stop gcode this appears. I'm no expert or even proficient with coding but is this right?
I am trying to add a start/end gcode to a print which was made in slice-up software. Any ideas?
    • 2 weeks later...
    If you are opening an already made gcode I don't think Cura can modify it. You can modify in any basic text editor and just copy your starting script at the beginning and the ending script at the end.
