so i did what you said about adding qidi i-fast and when trying to use a different material with extruder 2 it does not engage extruder 2, extruder 1 stays engaged..
On 5/9/2023 at 12:52 PM, Dr_Shred said:so i did what you said about adding qidi i-fast and when trying to use a different material with extruder 2 it does not engage extruder 2, extruder 1 stays engaged..
Mine is working with both. I'm now on Cura 5.8.0 though.
hukete 0
You can save the zip compressed file from the below link on your computer desktop.
https://drive.google.com/file/d/1XswhH7mArmQph75t3ZKR5GFOzcEKfd3Z/view?usp=sharing
Then uncompressed it and copy it on Cura configuration folder then replace the folders.
Reboot the Cura and you can add Qidi printer from drop-down list.
