Print job not starting (Intermittent)
darls
Posted · Print job not starting (Intermittent)
Hello,
I'm having an issue with my utilimaker2 where the printer does not reliably start print jobs.
Symptoms:
  • The printer completes its heating cycle and enters into the printing phase but (intermittently) hangs up (with 6 hrs print time indicated) and wont start the print job. The printer is not frozen as the print can be abborted and restarted via the navigation wheel.
  • Once the printer is running properly, multiple print jobs can be completed with no problem.
workarounds:
  • Power cycling the printer works periodicley, however only solves the problem 10-25% of the time.
troubleshooting:
  • Multiple STL files on multiple computers using the official Cura software produce the same results.
Possible issues
  • SD card? (investigating)
    • 1 year later...
        • 27 replies
