Holes not sliced as holes. Upgraded to larger nozzle recently.
Lars3DCura
Posted · Holes not sliced as holes. Upgraded to larger nozzle recently.
Recently i have switched my 0.4mm nozzle for a 0.6mm one. Since then my cura slicer version 4.5 does not slice the model correctly. The vertical holes are not sliced but sliced as 100% infill. I have added a 3mf file and two pictures. One of the model and one of the sliced model.
Am i looking over an obvious setting in cura which prevents the holes from being sliced?
Rails_bak_midden_A.3mf
    20 hours ago, Cuq said:
    Mesh Fixes  -> Remove All Holes
    Okay that was an easy fix.... That settings was on by default and was not shown when i searched for it. Thanks Cuq.
