Posted
· Cura 5.1 build plate empty after file open
Well, it appears to have loaded after a long delay. There was no feedback that anything was happening, I just notice after writing this the build plate had populated. Opening it again I see it has taken about 4 minutes for the "Open Project" dialogue box to appear.
I have found the cura.log file, attached is a trimmed version to show from start up to build plate population. I am seeing a lot of messages such as:
I guess it probing for printers. My printer is networked via Octoprint, the devices it is probing are embedded devices I am doing development work on and I would rather not have probed. One change since last running Cura is I have STM32F746-Disco devkit attached via USB which may be answering probes.
Posted
I finished work with the STM32F746-Disco devkit so have disconnected it and have since used Cura with no problems. So it does look like there is a bug or an undesirable interaction in play.
ukoda1 0
2022-08-28 12:07:59,133 - DEBUG - [JobQueueWorker [3]] USBPrinting.AutoDetectBaudJob.run [49]: Checking /dev/ttyACM0 if baud rate 500000 works. Retry nr: 1. Wait timeout: 15
2022-08-28 12:07:59,186 - DEBUG - [JobQueueWorker [0]] USBPrinting.AutoDetectBaudJob.run [49]: Checking /dev/ttyUSB2 if baud rate 500000 works. Retry nr: 1. Wait timeout: 15
2022-08-28 12:08:03,216 - DEBUG - [JobQueueWorker [2]] USBPrinting.AutoDetectBaudJob.run [49]: Checking /dev/ttyUSB0 if baud rate 500000 works. Retry nr: 1. Wait timeout: 15
2022-08-28 12:08:03,218 - DEBUG - [JobQueueWorker [1]] USBPrinting.AutoDetectBaudJob.run [49]: Checking /dev/ttyUSB1 if baud rate 500000 works. Retry nr: 1. Wait timeout: 15
issue.log
