Cura Feature Requests for update profile or revert
rdbischoff
Posted · Cura Feature Requests for update profile or revert
When opening a project file, I think it’d be nice in the opening dialogue instead of just “update profile” and “create new” for each the machine, print settings, and material settings if they could add an option on each type of keeping the current settings set. Does that make sense? Like say I’ve updated my machine profile since I made that project, I don’t want to have to go through “create new,” change machine profile, and then delete that new machine profile it made. That’s tedious. Also, the possibility of your print settings changing when you switch machine profiles.  1st Picture attached --> add another option of "keep current" basically
I have another one but it’s a bit more in depth into the same thing. Where it would let you pick and choose individual settings to keep or discard.  As well as changing printing profiles, where instead of just saying “all these settings are different. do you want to keep or revert?” Give the option to pick and choose settings to keep or revert when switching profiles.  2nd Picture attached --> add check boxes or something similar next to each setting for things to change or reject.
