Well, the machine test, and any other tests which want to connect to the machine after that, try to use auto detection of the serial port. However, the Beta4 can bug up if you have sertain types of other devices or bluetooth devices connected to your computer. (new version will be smarter in this aspect).
Nothing else connected to the computer....
Try setting the proper serial port in the preferences (this removes the auto detect)Also, the error in the console window would be of interest to me, you can "pause" the window by pressing [ctrl]+[c] while the console window has focus..
I did set the COM & Baud in the Preferences....here's where I get a little lost... :? the 'console window' your talking about is the Wizard or the Dos window?? The Wizard shows no errors at all...it's the DOS window that goes crazy..if you'd like to see that your gonna have to tell me how to capture it....
Thanks much..!! comming from a Pro I appreciate that...Print looks awesome btw =).
Oh, and the firmware that comes with Cura is just Marlin RC1. I don't think it will improve much over your current Marlin version, unless you use the old marlin from RepG.
If that's the case Im gonna leave it like it is then...it's printing too good to mess with..... thanks again.....
Daid 306
