[BUG #14377] Cura creates layer defects (model facets) depending on orientation
Ltek
Posted (edited) · [BUG #14377] Cura creates layer defects (model facets) depending on orientation
Cure 5.3.0 (assuming also in 5.2.x) 'creates' a defect when the largest 100% flat face is on the build plate (it is Layer 1)
When that face is layer 152 (top most layer), that defect is not there.
Looked at the model in  X-Ray & Wireframe (using Microsoft 3D Builder, Meshmixer, and Cura)... there is NO mesh facet where Cura is putting it after slicing. AND Prusa doesnt have the same defect no matter what orientation I slice the model in (attached photo)
STL & Photos attached.
UnderMountCase_defect.stl
Edited by Ltek
    • Ltek changed the title to [BUG #14377] Cura creates layer defects (model facets) depending on orientation
