Travel Speed
3dprintingagency
Posted · Travel Speed
When Cura was upgraded to the 5.x path, the maximum Travel Speed was changed from 150mm/s to 120mm/s.
That makes for a HUGE jump in print times and is the reason I'm still on 4.13.1. ☹️
Could this either be changed back or could someone official at least explain why this was done?
Thanks,
Ron
    If you have a limitation it's not in Cura but in the printer definition. You can change this limitation but if your printer is in the official list they are a chance that you need to do it on every new installation.
    • 2 weeks later...
    I don't believe that's true but please correct me if I'm wrong.
    In 4.13.1 I'm able to set it to 150 (that's the max it will allow).
    When I installed 5, it took my definitions from 4.13.1.
    Now in 5.x I can't set it higher than 120.
    Exact same printers and filament definitions in both situations.
    It's an issue with your printer configuration ..   I can fix a value of 300mm/s of 600mm/s if I want in cura
    In cura the limitation for the maximum Travel Speed is define by
    math.sqrt(machine_max_feedrate_x ** 2 + machine_max_feedrate_y ** 2)
    So it's dependant of the  Maximum Speed X  &  Maximum Speed Y  .. Have a look in your printer settings and increase this value if you want to go upper this value.  So no it's not a Cura Limitation and if something as change it's a modification made on your printer specific configuration ( Which is not Ultimaker's responsibility if the machine does not come from them)
    Posted (edited) · Travel Speed
    As you haven't give any information about your Printer I suppose that it's an Anycubic i3 Mega X and the culprit is called NilsRo https://github.com/NilsRo
    That's the only printer limited to 120 mm/s  and  for them we have a modification between 4.13 and 5.0
    New definition :
    "speed_travel": { "value": 100.0,  "maximum_value": 120.0 },
    and he made the modification here : https://github.com/Ultimaker/Cura/commit/435e9a7924cda621eb04bd9048a09df05bd9cfd2
    So if you have any question ask him why he made this 'stupid' modification .   'Stupid' because at it is no longer linked with Maximum Speed X  &  Maximum Speed Y  you need now to modify this limit in the json file ( and certainly modify for every futur release of Cura)
    Edited by Cuq
