First layer incorrect when sliced (solved)
judge2005
Posted (edited) · First layer incorrect when sliced (solved)
The attached STL file does not slice correctly. The first layer is just one line. The second layer shows the correct cross-section. Lowering the model in to the bed doesn't help. The first layer is still one line after slicing. I checked the model in Prusa slicer too, which slices it correctly, but I want to use Cura, not Prusa slicer (for various reasons).
Cura version is 5.2.2 on MacOS ventura. STL file was exported from FreeCAD.
top.stl
Edited by judge2005
    ...and that something was I had Initial Layer Horizontal Expansion set to -0.75mm. BTW I used the Profil Analyser (sic) plugin.
    Edited by judge2005
