Support Blocker not blocking?
Andrew_W
Go to solution Solved by Cuq,
  • Solution
Posted (edited) · Support Blocker not blocking?
If you want to supress this issue reduce the value of the : Support Horizontal expansion (0.5 should be enough)
Or if you want to keep this expansion for the upper support, Increase the Minimum Support Area Value to 10 ( the size of your hole )  .
For me it's a bug it's a temporary workaround but should be report on the github ( even if I don't think it will ever become a hight priority )
Edited by Cuq
    • 3 weeks later...
    Posted · Support Blocker not blocking?
    Thanks, this work OK for this part.
