Posted
(edited)
· Firmware 8.1 Bug? ERR999 on API "pause" call,
Hi Walter,
Thanks for bringing this to our attention.
I can confirm that the behavior of the /print_job/state REST API endpoint has regressed with our 8.x firmware release. My apologies for the inconvenience this must have caused!
I've just pushed a fix for this to our internal systems, but I can't make any promises as to public availability of this fix yet. I'll keep you posted if I can share more.
For now, I can also confirm that the problem appears to be submitting a request to pause the printer, while the printer is currently executing a "resume from pause" command. If you would be able to add a check for that to your script, that should provide you with a workaround. (As far as I can see, asking the printer to pause while it's currently resuming, previously just caused your request to be ignored by the printer. The ER999 you get now is the regression. So adding the check would probably be a good idea anyway.)
Onno 6
Hi Walter,
Add more info about the workaround
walterww 2
Thank you very much!
[quote]So adding the check would probably be a good idea anyway.[/quote]
Yes, I will do that!
