Mixed Mode Printing Vase/Infill
Posted · Mixed Mode Printing Vase/Infill
I'm printing an over sized C9 light bulb prop in vase/spiral mode and the very tip is not filling in properly.
1) What would you recommend so the tip properly fills in?
I'm thinking maybe print "normal mode" for a base, switch to Vase/Spiral, then back to normal mode to fill in the tip.
2) Is this possible in Cura?
If not I might have to manually edit the gcode.
3) With an Ender 3 S1 and Merlin can I switch mid print to relative extrusion?
Math is hard and this would make gcode editing simpler.
