Print material configuration change error
tmostad
Go to solution Solved by tmostad,
Posted (edited) · Print material configuration change error
I get the above error message when I try to print and don't know how to fix it. I override the configuration to get my UM3E to print the file but from what I can see it shouldn't be an error.
Edited by tmostad
    • tmostad changed the title to Print material configuration change error
    • 2 weeks later...
